Introducing V2 Axis brake guide bushings
major change is internal O ring for better grease retention and NVH
Axis precision guide pins promote more even pad wear and consistent Brake feel by not letting the guide bush flex allowing your brakes to squeeze evenly similar to multi piston BBK kits
can also supply OEM replacement or performance Pads and disks to go with them
