ChefDJ
We have a 2006 E85 Z4 3.0 which has the common sticky/notchy steering problem which is always experienced in hot temps, for example driving after the car has been standing in the sun for half a day.
The problem is mostly experienced on the highway when going down a straight, and the steering wheel needs a bit more force than usual to "un-centre" it for changing lanes or correcting lane positions or whatever, as if the steering wheel gets stuck in position.
We read up about a multitude of possible problems and their solutions, ranging from replacing the steering rack to upgrading the ECU etc. I believe in the States there were actually court cases against BMW AG for this problem and a recall campaign was started by BMW. I know nothing of this happening locally.
One of the less costly possible solutions was to drill a small hole into the steering rack and fit a grease nipple in order to apply lubrication and seal off the unit, which is what we did today. I unfortunately don't have pics of the process.
We will be monitoring the car over a couple of weeks to see if there's a noticeable difference.
The repair took about an hour or so and an extended grease nipple was used which isn't costly.
Will report back at some stage.
