Hi Guys,
I've recently developed a problem. When I press the unlock button on the key fob, the driver side door lock does not open. I have to put the key into the lock and turn it. If I press the unlock button twice, then the passenger side door unlocks (but still not the driver side).
This used to happen intermittently, but now it happens every time.
I think it's the actuator in the driver side door. I phoned the dealer for a quote, it's R 950 for the part and about R 1000 labour. Do you think this is worth it, to save some time? Or is it an easy DIY?
What do you guys think? Am I right in my guess it's the actuator? and what are my alternatives? Has anyone had a similar problem?
Thanks in advance
Thanks in advance
