the amount of octane you need is determined by many factors making it almost impossible to say what octane you need without testing under your specific driving conditions...
once you have the right octane level adding more will NOT improve anything by adding more and it just cost you more on fuel...
obviously copious amounts of data logging will be the best way to find out what octane you need for your car but its not practical for most people...
the easiest way to determine what octane boost you need is to monitor your fuel consumption...
simplest way to do this on most of our cars is to reset your trip computer at at every fill up... you need to do this for two fill ups minimum to get a good baseline... you can set the baseline with octane boost as long as you use the same boost level over two tanks...
once you have a baseline you can add octane boost at the next fillup... a reduction in fuel consumption on the tank with octane boost will mean your engine needs it to run an optimum
you can then experiment by adding more or less boost in your next tank till you find what level your car likes...
