MLorgat
same part numbers and specs as mine, you won't get those exact spec fluid from LM. They make a 75w90 which should work for both but I didn't wanna chance it.I booked mine in for Thursday.
G01 X3 20d Xdrive (98k)
Going to do Transmission, transfer case and both diffs.
BMW asking +- R4000 for diff oil though.
Differential oil
Rear diff = BMW Hypoid axle oil G3(70W80 GL-5) part number: 83222413512
Front diff = BMW Hypoid axle oil G2(75W-85 GL-5) part number: 83222413511
Can I just buy LiquiMoly of the same spec for 1/4 of the price or do you guys recommend sticking to OEM on this?
From the research I've done, guys who used the ravenol were very happy, with some even choosing it over the OEM without looking at the price. Their engine oils are premium quality stuff and also quite Expensive so it's surprising that the diff oil was so cheap (relatively)
Here's the links:
Rear (70w80): https://shop.ravenol.co.za/product/ravenol-vgl-sae-70w-80/
Front (75w85): https://shop.ravenol.co.za/product/ravenol-dgl-sae-75w-85-gl-5-ls/
These should correspond directly with the BMW part numbers and spec
