2014-2017 730d reliability
Del-Bosc
Hi All
Looking for some info on the common issues related to 2014-2017 730d.
Are these cars as troublesome as they are made out to be?
Do the electrical gremlins creep in at this age?
Any after market warranty available for these cars that will cover the gearbox or engine components or electrical system failures?
What should you have looked at, as preventative maintenance on them?
husaindindar
Hi.
I don't think there's any major gremlins. Engine and gearbox are a proven reliable combo. If the mileage is right, the gearbox oil should be changed and all should be good.
It's more the maintenance items that are expensive. Brake disc's, pads, shocks, suspension components etc....
Del-Bosc
Hi.
Thanks for this feedback. I am considering a 730d or S350. The cars available at the moment seem like good deals. The 730d seems to be cheaper when comparing same year models. I’ll do some research on the wear and tear items. Any recommendations for reliable Indy mechanics around the JHB north area ?
Xcede Performance
We do a lot of these both tuning and maintenance.
They engine and gearbox are hassle free. Just make sure you get the gearbox serviced on time and do the engine oil changes at 7500km intervals.
Suspension needs work as they get older (control arms and shocks like any normal car), engine mounts tend to wear faster than other cars. Brakes a considerably more expensive but they last unlike on the F30's
No major gremlins like the older ones.
AshG108
Naturally,
You are looking at an electronically complicated vehicle, they normally would soft-close doors, electronic features available for 4 instead of 2 so climate control in the rear etc. Then also remember if it has Adaptive Suspension or Sir suspension, it is a cost as well...
Engine and Gearbox are easy maintenance items, but when it comes to other luxury feature items that the 5s and 3s didnt get, you need to research these in depth to know what you in for should something fail and you need to temp fix it or replace it...both end of the spectrum.
They a brilliant cars but without a warranty and even with, you going to have to have a healthy slush fund for them hence the lower prices on them after a while and especially when out of plan and warranty.
TurboLlew
The S is the superior luxury vehicle... but also much more expensive for suspension, electronic issues and general quality issues with the plastics (anything not wood, leather or metal unfortunately). The S Class engine reliability varies GREATLY across the range but you don't seem to be looking at the problematic ones.
For my money it would be the 7 - also one of the prettier generations of 7er.
My default advice is to thoroughly check out the air-conditioning system for whatever car you are looking at - this applies to any modern car. The cost is one thing... but ripping apart most of the interior/dash to get to the parts can leave you chasing down squeaks or rattles caused by internally broken parts just cobbled together while doing this (it is not a fun job for anyone involved as I am sure the dealers can only book a fraction of the time this takes... the techs probably also need 6 weeks of physio after this).
tamgoem
Let Uncle chip in here. Been here done that.
Got a W221 S350 Bluetech in poverty AMG styling pack. One of the struts checked out about 8 months into my ownership, it was 11k to replace and 35min at a shop in Kempton. While it was in Capetown the workshop that did the pre-delivery service fucked up some major things like shoving a D1S blub into a D2S socket, claiming to have done the cabin filter changes and such and one of the things they screwed up was the charge pipe so it was over the course of 4000km spraying some oil onto the alternator, so that checked out a a week before i was to fly to Zilleville and pick it up, 15K because while a common engine, it is S class only bits and pieces. BMW thankfully don't do that. I believe everything that hangs off that engine is common with all other similar aged G series cars with the same drive train.
It has some strange issue where the rear headrests and drivers lumbar support will sometimes work and sometimes not. I suspect this relates to some Capetown "i know a guy that can do it cheaper" fuckery that was going on since there is a bit of a rattle from the rear parcel shelf and alot of the electronics do live there. Not really bothered much with that in 2 years. Other issues i have had with the car was a result of previous owner and a dubious tune/tuner.
But now to the question at hand. Not once in the buying process did the thoughts of "cost of ownership " cross my mind. I think back to when i was 15 sitting in the back of a friends dads W140 S500 and i asked him about fuel use, "one does not drive a S class and talk about such things as fuel economy". The same rule will apply to a 7 series. No matter how reliable it will be, it remains a old BMW with old BMW issues, and expensive when new old BMW issues. So you have to understand a set of good rubber will be 20-40k, suspension bits are going to be 10-40k, the odd little annoying failure like a softclose door is going to be a complete pain in the arse. The most minor of accidents that takes out a headlight might write the car off kind of costs are involved here. It is going to be expensive no matter how reliable it is.
Me i voted with my money and it is not a 7 series sitting around, playing who can bankrupt me with the Z at home. It's a big blacked out S for a reason. It is simply "sonderklasse"
