discussion BMW E90 Severe Oil Loss
Pap3r
Evening,
I hope you're all doing well.
I got an 2007 BMW E90 320i that I have been driving as a hand me down from my parents. Been having the car maintained and serviced at BMW as that was where my parents always had it serviced since 2007. Had the timing chain replaced in July '26 at BMW, as I liked the 2 year warranty despite the expense. Oil sump was removed and cleaned according to BMW too. However when I started the car on Friday and when I drove 800m away from my place. Red oil lamp came on, bad car shudder, but I managed to pull into the Engen petrol station a few meters away from the time of the shudder. Opened the bonnet, and saw all the oil on the bottom of the engine bay. Had the car towed to BMW. They came back yesterday saying the cause of the oil loss was that 2 bolts were loose on the OFH, which caused the gasket to pop out, and jetison ALL the oil within a couple seconds. There's a video of it but it is too big to upload. I can see it sticking out between the two surfaces.
I suspected workmanship, negligence and oversight due to my engineering background. I saw the receipts from 2024, that the OFH gasket and PCV valves were replaced. So that made me wonder why bolts failed so suddenly. Went to BMW, DP wasn't there, so spoke to Service Manager.
He said with the foreman. Due to the age and high milage of the vehicle at 240,000km. The mating surface and threads of the OFH are no longer guaranteed to be in spec, so therefore they cannot pay for damages caused by failed bolts. The vehicle is test driven, at various temperatures, and loads and it passed at the time of hand over for the timing chain work. Any negligence would have been seen immediately. The car engine is aluminum, and the bolts for the OFH are steel, and steel over time will wear down the threads, causing them with the heat of the engine, to be stripped and loose. Heat expands the metal, and therefore, cause enough play to pop the bolts out. They can offer 10% discount for the parts as a resolution. I am at a loss and not sure what to do.
I argued that the bolts were definelty overtorqued, and failed due to the constant pressure from the OFH. They said everything in spec as a counter with age and that it lasted 2 years. I then said, if you hang a picture with a skew screw, it will hold, but it will eventually fall off due to incorrect installation procedure. They said if the material of the wall was old, it will also cause a correct installation to cause the picture to fall off. I asked why didn't they report of wear on the threads, and they said it was in spec at the time of installation.
I am concerned that the rods or bearing are absolutely shacked, or the guides on the timing chain broken etc. Did a scan on the car before handover at BMW, and saw it had misfires on all 4 cylinders, and VANOS issues. Prob due to the oil loss.
BMW wants essentially 10k for new threads, new gasket and oil change to test the car which is now a possible lemon due to poor workmanship at BMW, which you expect a car looked after by them to be in good mechanical condition.
Car has never overheated and been serviced on time, and oil changes every year at BMW, at the same dealer.
I think I will start taking the bus, until I can find a nice diesel or that V6 Toyota Camry. It feels so shit lol.
Just to clarify. In the second paragraph you say "Had the timing chain replaced in July '26 at BMW" but further on you say the receipts were for work done in 2024. I assume that is a typo and that the work was done in 2024 and not 2026??
It sounds like bull dust to me anyway as it is the first time that i have heard of oil filter housing bolts suddenly giving way like that. In my opinion it should start as a very slow oil leak but not a sudden loss of oil as you described. Were there never oil on the floor/ground in the last few weeks before the incident? If i were you i would definitely investigate this further.
Pap3r
No typo. Timing chain was paid and completed in July 2026. Oil sump was removed and cleaned according to BMW. Oil Filter housing gasket and PCV valve and related tubing replaced in September of 2024 as preventative maintenance. I will try find a way to upload the video on a lighter compression tomorrow. There was never oil on the floor in the garage or in the bottom of the engine bay, the last few weeks. This really felt like a sudden expulsion of the gasket out of the housing that lead to sudden oil loss.
