technical E90 Aircon blows cold but not hot
husaindindar
Howdy....
So my E90 has a bit of an issue.
Aircon blows propper cold when on cold setting, however if I use the hot setting on full 28deg, its just blowing normal air around.
And yes I did toggle the wheel on the vent to the hot setting
Even if I turn the aircon off and use it in manual mode, I'm guessing this uses the cooling systems heat to warm the air?
It started last year, when it used to just blow hot air to the passenger side and not the drivers side. Now its not blowing hot on both sides.
Any ideas? I was thinking a regas might solve it, but its not getting hot even with aircon off, assuming it uses cooling system heat?
All this blowing talk, gets me hot ngl...
Peter@AEW
Your aircon is separate to your heater.
Likely a failed heater valve which has failed closed and will not allow hot water to circulate in the heater core.
Donz135
Howdy....
Yep, like Peter said, most likely the heater valve as the heating and cooling systems are separate.
