help please 2010 bmw 335i xdrive N54 E92 im at a loss
2010e92-n54
i own a the bmw for over a year now, yesterday after washing the car i lost/drained the battery sitting in the carwash bay long enough to wash her 10-15 min tops.
didnt wash the engine bay. my queston is this what may cause the battery to get drained or where to begin to start looking at any help will be appreciated.
ive replaced the alternator and battery recently as well her in a bit ill run the scan tool and see what it pulls up
Since you had the car washed I would check for water leaking into the car. Check the carpets for water. if they seem damp at all i would remove them and check all the electrical connections underneath.
2010e92-n54
Me and my partner did that including the ecu box under the hood on passenger side. Bone dry. We hooked up jumper cables and It started first crank.. idk im are a loss
NBN
You say the battery was recently replaced. Did you replace with one that has the same cold crank amperage as well as amps? Also very important to have the battery registered to the car to ensure that it syncs to the cars alternator
modocrat
Yep, I replaced it with a Willard 658 90Ah. Battery was coded/registered via Inpa/Ista.
NBN
Not you... My initial response was meant for the O. P... He stated in the very first post that he replaced both the battery and alternator
2010e92-n54
How do I register the battery, I've never owned a car that I've had to do this with
NBN
You can use a plethora of tools such as Carly, mhd, Inpa, protools etc etc... But they requiree a combo of paid subscriptions and hardware/software/apps
My suggestion would be check with a reputable battery reseller, they might be able to help you out at a minimal cost.
2010e92-n54
Took a chance hooking up jumper cables to E90/E92/E93, lucky u did'nt blow up the FRM..
I done that also, 850.00 dollars later for a new one. Sense installing the new one now my widows and mirrors operate opposite, my driver side works using the passenger side buttons and passenger side with driver side buttons. Any suggestions as to why, I have a feeling that new FRM needs to be programmed even though the dealership them self wanted my VIN# before selling it to me?
