New here and already needing advice
Please chime in if you can
Just got a 2013 125i with 82k on the clock
Been experiencing some hard morning starts. Will just crank and crack till you stop it. 5mins later will start
Local bimmer specialist feels its the ECU. 1st had crank position sensor error. Then an array of errors after refusing to starts. Could it be that the array of errors is from simply not starting due to a crank sensor error. He seems a little too keen to just replace the ecu.
Anyone experienced anything similar?
Thanks all
Evan
Thanks all
Evan
