2018 X3 G01 20d M Sport LCI Conversion
Shaheenem
Bought the wife this 2018 G01 X3 20D Msport after selling her Tiguan Rline TDI last year.
Very well specced car with a host of factory options. Harmon Kardon, Lane assist, Pro nav with gesture control, Pan roof, Adaptive LED Headlights, heated seats, Rear windows blinds, M Sport brakes, Digital cluster and list goes on.
Had her detailed after purchase.
Bug finally bit and got a set of LCI Tail lights for a good deal. Small wiring changes were needed to the plug. No coding required.
Then toyed with the idea of facelifting the car using OEM parts. Didnt realize how much work and parts were involved but slowly starting getting all the parts together.
Bought an OEM front bumper, OEM rear bumper and 20" LCI wheels with new tyres.
Finally got a set of OEM headlights.
After lots of searching and checking OEM parts lists, managed to source all the required grills, brackets that sit behind the bumpers front and rear etc.
Once all the parts were sourced I started fitting them at my shop just to make sure everything fitted correctly before sending it off to paint.
Final step was to take it to my panelbeater to get everything painted. Once painted I chose to go to the panelbeater and assemble the car together with them just to make sure it goes together perfectly. Couldn't find a set of OEM tail pipes locally as most places only wanted to sell the complete exhaust so ordered a set from overseas again.
Assembly
Pics after getting it back from the panel beater. After fitting all the grills etc. Left the mirror caps to be painted black. Added some OEM heritage badges for the wheels and bonnet and boot lid.
Basically completed the converison late July.
Tail pipes fitted and this is the final look of the car.
PsyCLown
Very cool, were the LCI headlights a simple plug and play item? No coding or any extra work needed?
Shaheenem
Thanks guys
Headlights required an emulator and additional coding for them to work as the Pre LCI uses BDC2 and the LCI uses BDC3 (Body Domain Controller)
Turn signals on BDC3 works via CANBUS
Nastaliq
Great job.
I have been thinking about replacing the rear lights on the G05 as i much prefer the facelifted 3d look, versus the flatter linear look on pre LCI.
What wiring changes were requred for this on the X3?
Ive read the pin layout differs pre-lci versus lci?
Shaheenem
Great job.
Thanks
As you mentioned, just the pin layout is different so had to depin the connector and place the pins in the correct slot for the LCI taillights
Im not sure on the G05 but will do some digging and see whats needed. I would assume it might be like the G30 where coding is needed only but may need an emulator or module that will need coding as well.
Nastaliq
Thanks
Im not sure on the G05 but will do some digging and see whats needed. I would assume it might be like the G30 where coding is needed only but may need a emulator or module that will need coding as well.
Thanks bru.
Appreciate it.
FueY
Well done man, car looks awesome - if you don't mind be asking, how much did the change of the rear lights set you back?
This is brilliant bud well done on the conversion. BMW really got it right with the LCi
How do find the G01 compared to the Tiguan?
Shaheenem
Thanks guys
Around R15000 for the set of tail lights new OEM.
Definitely feels more solid then the Tiguan. Had a chat with my wife about it last night infact, and we both agreed the X3 is a much better vehicle.
