E39 Touring M5
Peter@AEW
A bit of progress on the touring.
Although we cut the floor from the sedan I was not entirely sure that the thickness of metal used in the sedan would be sufficient for the touring so I acquired 1.2mm steel to cut a new floor from.
A few pics of the new floor in place although not welded in yet.
That is a lot of work that goes into the floor, didn't realise the boot slam panel also needs to be removed. Good progress
Peter@AEW
excuse my ignorance Peter. Was the floor cut for exhaust/fuel tank reasons?
It was cut and modified to accommodate the right rear silencer as well as the battery.
Normal e39 cars have a spare wheel and battery location on right rear.
M5 uses a flat floor and the battery is located in a tub center of the boot.
