EBZ911
Hi Fanatics,
Driving a E90 330d, recently noticed a sudden loss of power for a few seconds then all of sudden a surge of power and car drives as normal. Use to happen after driving to work, parked off 8 hours start up and go and a minute later the issue occurs. Getting more frequent, took it to the mech, he suspects a blocked EGR.
Question is if it is, will this not be the time to close off the egr, do a removal of the cat and dpf. Do a delete of the above and upgrade/update the software?
Should I rather get the egr cleaned 1st,make sure that is the issue before doing the above mentioned plan? My concern is if it's not the EGR and I do the updates and removal of the hardware and it doesn't solve the issue I may be going in circles š š
Any suggestions will be highly appreciated.
T.I.A
T.I.A
