Howzit,
Considering buying one of these.
MSport auto with 155k on the clock.
For sale by BMW, one owner, fsh.
Good as a daily driver? About 85km per day.
Is it a good buy? Any concerns?
Thanks
Hi there
I own the exact same car, purchased it two years ago with 162 000km.It has never skipped a beat. If the car is well looked after then there is no worries in buying at this age and mileage. I personally would rather buy an older higher mileage, but better quality German car than a new, smaller lower tier brand with half the milleage.
I did my checks with Coisman, and saw it was a legit one owner car, and the dealer provided a copy of all service history.
My advice in terms of buying is ask Coisman to check it for you, then check its history. check it is a happy car that didn't need much repairs, either than the usual services and brakes etc.
In terms of a daily... what an awesome car. Its quiet, very comfy and has power to be a good cruiser. Space in the rear is excellent.
We use ours for trips to Maputo and the Drakensberg, These days with the state of our roads, the benefits of an suv are unparalleled. The higher ride allows you to safely see further ahead which makes a difference on long trips as you can pre judge any situation. And being an Msport, its best of both worlds. This car is a very capable handler with the Msport package. So you have the safety and practicality of an suv, with an engaging and fun handling.
My worst consumption is 9L/100km that's with daily of 7km drives with just robot to robot driving. Long distance is sits at mid 6L/100km, so i get to Maputo on half a tank.
Your biggest expenses will be tires if you choose to stick with Runflats. You looking at around 20K for all 4 , or you can get a spare wheel and it will cost half that should go for normal tires. Just bare in mine with Xdrive you need to keep all 4 tires basically the same amount of mm not to put too much strain on the transfer case.
You need to go to ZF and let them analyze your gearbox, then if you get the all clear, do the gearbox oil service, and do the oil change for the transfer case and front and rear diffs. Then this car will be reliable for a long time to come.
You also Can remap the car. This completely transformed the car. It was then a safe overtaking car at any speed.
There is a reason they are in such high demand, and clean ones demand such high prices.
Good luck with your choice
Go for it!Howzit,
Thanks
Howzit,
Thanks
Don’t know what your budget is or why you are considering an SUV. I say don’t do it. It’s too old, older tech, doubt it’s very economical on diesel.
Get something newer/new in the same budget.
Go for it!
I have a 2011 non m sport. Full spec
20d avg consumption 7 short distance
Long distance less than 6L per 100 km
When u get it.
Get your front and rear diff oil changed.
Transfer case oil change
ZF oil and filter done. (Gearbox)
Change engine oil every 10k.
And u will be good to go.
Keep funds a side for tires, all four will need replacement same time. ( luckily for me my front shaft is disconnected)
After market parts are reasonable well prices.
Or even get an after market warranty. Less then R500 per month. ( I had after market warranties for more than 8 years with no issues from them.
Try and plug vehicle in with a proper scan tool to check mileage, errors and codes etc
I can't comment on the X3 itself, but I have 2 cars with the same powerplant. Reliability and maintenance goes hand in hand. Various threads on the forum as to how to maintain these 20d's.
Please also check vibration dampener/crank pulley, vbelt/serpentine belt and tensioner. These generally tend to fail in the region of 150 000km-200 000km. Rather get it done before it fails- dealership fit and supply max R14K.
Is there any particular reason you'd rather buy a X3 over the 3 Series?
Great vehicle bud.
Reliable and economical. Above posts mention the preventative maintenance that needs to be done.
Verify history with Coisman by sending him an email with the requirements like vin number etc.
Bud these sell for around R250k give or take.
What SUV or even sedan can you get newer at this price range that will deliver what a F25 20d does?
I didn’t check
