kgosi_f30_340i
I have an issue that sort of started a few weeks ago. I would get a battery discharge every 3-4 days when I start up the car and won't get it for 2 days or so again. Then last week Tuesday I drove about 20km from my house, parked at a restaurant and when leaving the restaurant 2 hours later the car wouldn't start. I would hear the ignition go on after pressing the start button, but no start. I jump started the car assuming it has to be the battery and that worked.
After a few days I figured out that the boot latch had a fault which kept the boot light on when the boot is closed, which I assume may be draining the battery. That is now fixed. I also disconnected a faulty light on the passenger sun visor which I believe the switch on the open/close mechanism is broken. I then took in the battery to be tested and the battery is perfectly fine. 90% on condition and 85% on charge. I then tested voltage on the battery while connected to the terminals and all is perfectly fine. Reading a 12.6v while the car is off and a 13.7v while the car is on. But still not starting on its own, need to use the jumper pack in order to get a start.
Next was checking for parasitic draw so I did the whole process of testing every single fuse from all fuse boxes and nothing is drawing power while the car is off. Then I tried to see if I can see what the voltage drop on the battery is after attempting to start and it is huge. I charged the battery to 13.0v and attempted to start the car without the battery pack, didn't start. I then checked the battery again and now I was on 12.3v. This means (as far as I can tell) the starter is pulling more power from the battery and discharging the battery after attempting to start, dropping the battery voltage.
Is there a reason this could be happening? I would assume because the car starts with no issues when plugged to a jumper pack, the starter is actually fine. I have tried looking for where the starter relay is but I can't find it.
And also what would be my next step? I really don't want to have to take the car in if all I need is to change the relay but looking for advice on what else could be causing this and if its a common issue or not.
