technical Help! X5 Digital Cluster Problems
dino_rox
So my 2016 F15 X5 cluster started acting up a while ago
Randomly started flickering one night while driving ,
Then each time I start it it’s blank and gradually works itself close to normal and the cycle repeats itself
Has anyone experienced this before ?
I doubt the actual cluster is faulty
And the few folks I’ve asked hasn’t seen this before
I’ve also had a guy check the wiring etc and said nothing is loose on the inside ?
Pics below.
dino_rox
There was someone on one of the international forums or reddit (can't remember) who had something similar happen: It was a GPU failure (the VRAM became faulty and caused artifacting).
Yes I think I came across that thread ,
Just weird that it’s such a rare case and no one locally can help me fix it .
I did.
Also removed the cluster to make sure there aren’t any loose connections.
So...Mine had 3 shorts on it....no lose wires...I even checked myself. 2 fuses were gone and on the one speaker, the wire was broken inside but on the outside, perfectly normal hence I recommended that bud.
dino_rox
Same cluster ?
