Wat?
Not to be a pedant, but we established early on in this thread that the subtleties matter. The nuance of RON v.s. OCT seemingly led to you flashing a car with a 95OCT map (which is actually 98RON equivalent) when the car was fueled with 95RON. Essentially assuming that RON = OCT.
Gotta 'speak' right so wires don't get crossed. There's potentially a lot at stake, as you say.
Thats correct. The car is currently stage 1 on 91 Oct which is the 95ron map. The lowest quality fuel option on the application.
I understand your point. It was a simple mistake. I'm sure with you're experience on the app it's a fairly easy thing to notice that you don't get OTS maps that go lower than the one I am running in terms of petrol quality.
I will try and run some liqui moli and see if that helps the timing corrections.
This is a science and each engine is slightly different.
The disparity for performance on a day to day basis is lower than I made it previously seem. The car on stage 1 won't run less than 270kw with that being a bad day, on a good day it will run as high as 290kw.
I guess heat plays a huge role as well.
I have also found differences when refreshing tunes.
Something that is very odd and I hope so one can help with this.
The car will at times stay in boost even when i am fully off the petrol causing it to still go forward (can't think of saying that in a better way).
I am not sure what could cause that
