General.Massacre
***UPDATE***
Hi guys, been a while since my last update, and a few things have happened.
Firstly, beginning of October i sent my car to Carbon Doctor for a carbon clean, i will update with the images of the valves etc soon as i get them, i forgot to ask for the pics.
With the carbon clean i also opted to change to new Glow Plugs as i was getting an error on Cylinder 4 for Glow Plug resistance or something.
So purchased 6 new Glow Plugs from GW,
Dropped the car off at Marchand. and within the first day, the carbon clean was completed, Intake Manifold cleaned and EGR system cleaned.
However, as seems to be the case with so many diesel motors, the inevitable happened, and 3 of the 6 Glow Plugs snapped in the head, which made my heart pound as if you cant extract them, its a head off job. but Marchand and his contact managed to make a tool to extract them, took some time, but they came out, and the new ones were put in.
When i got the car back, i was getting errors for boost, but Marchand and i already discussed an issue prior to me dropping the car off whereby i was getting only a max of 3psi when monitoring with ProTool (More on this later). and we suspected the Small turbo to be at fault.
So i had begun preparing to send the car in for a turbo repair. but Marchand had been fully booked.
So while i was waiting for a gap, i decided to contact Grease Monkey Motor Garage, and they could fit me in on the 17th Oct and asked me to bring it in. so i arranged to do so and the car got delivered. i requested the following:
Vacuum System test (If failed they were to replace all vacuum lines)
Check Small turbo and recondition)
I checked in with progress on the first day, and they hadnt started yet, checked in the 2nd day, and they said the vacuum system is holding vacuum correctly as it should with no issues, an they were going to check the turbo next.
The small turbo was initially checked having no shaft play, and the shaft had not seized. and spinning freely. so it was now to check the large turbo.
This is what was found:
No i cannot see how a full rag got into the intake system, i can understand where, and the possibilities, but where, i cannot say, so i contact Marchand who from the Carbon Clean were the last to work on the car, but according to him and his camera footage etc couldnt see how they could have left this in in the system.
But, true to the absolute great man that he is, he took responsibility and offered to pay for the hardware repair on the turbo. so anyone reading this, this part of the post is NOT a slate to Marchand or Carbon Doctor, but just a step by step happening of all the events that happened. i respect Marchand 10000% and will undoubtedly use him and his services again, Accidents happen, and he offered to make right on this one, even with the uncertainty that it was his fault. So sir, if you read this, I thank you.
Now, with the issue found, it was case of stripping the turbo out the car, which, unfortunately, from drop off of the car, to having the turbo removed, had taken 3 WEEKS. i was very frustrated and irritated with the time taken, but gary (Grease Monkey) said that due to the queue of cars, they had obligations to get those cars out before month end, which, judging by his amount of cars in the shop, I understood, so had to be patient.
Once the Turbo was out, the aftermath is as below:
The rag had plasticized itself to the turbine blades.
I agreed on going ahead and the Turbo was repaired and put back together:
I eventually got the car back, drove it from Centurion to Fourways (to gym, boet thing to do i know), when i left gym, i is tarted the car and got a Low Coolant message, and when i opened the bonnet i noted the coolant bottle lid was not closed, but instead only on about 2 threads. so i lost all the coolant in the bottle, if i had been stuck in highway traffic, id have overheated for sure.
i showed this to Gary, and he took responsibility and apologized, and offered to pay for the new coolant and flush.
Anyways, since i topped up with new coolant and distilled water mix, I've monitored it, and it hasn't dropped again, so all good.
I was however still monitoring my boost with the car running well again, and i was still showin only 3psi on the ProTool logging.
So i contacted @DannyBoyOPC and he offered to come around to my place after his customer on Saturday, while i was waiting for him, i went to Adendorff and purchased a vacuum hand pump so i can test the Vacuum and Solenoids myself.
Actually a great bit of Kit, and ill create a new thread for the Diesel guys on how to test your Vacuum systems.
Thread here:
Danny arrived, and we tested the solenoids, and vacuum lines, all held boost perfectly as gary stated it did, so thank you.
We decided to strip the Solenoids out the car, and we noticed one was repaired with QBond at some point in its life.
Tested these manually to battery power, and they seems fine, but still bled vacuum, which is normal, but a little faster than id have liked, so i will be replacing these soon in anyways. along with all new vacuum lines, so stay tuned for that post.
Danny and i put everything back together, and decided to go for a drive, and he used ISTA to monitor the boost parameters, which were perfect, i was targeting 1700mbar (1.7bar/26psi), and reaching 1700mbar of boost,
So decided to reconnect my protool and it was still reading only 3psi max boost.
Switched the reading value over to BAR and it was reading the same as ISTA, all perfect, we then realized that protools data whether either BAR or PSI was reading in BAR, so i have logged a issue with Bimmergeeks and they have accepted the issue and are correcting the software with a new update release on its way.
So far the car is driving very very well, and i think after new solenoids and vacuum lines, it should be a fair bit more responsive.
but for now, the car is error free, boosting, and a pleasure to drive again.
So for everyone involved:
Marchand @Carbon Doctor, thank you for being an absolute gent and so professional.
Gary @GreaseMonkey Garage, the work was done well in all fairness, and none of the oil or coolant lines are leaking (i was sure to check this very closely lol)
Danny @DannyBoyOPC from DSC Motorsport, thank you for always helping and coming out of your way to check the car with me. your sene checks and experience go a long way.
Thanks for reading guys.
Thread here:
