e83 drivers window switch
Ozzycat
Hi. The drivers door window switches are not working. The cluster lights up when lights are on except for the window lock light and the mirror adjustment works on both sides so power is there. All other door window switches are working fine. I have removed, taken apart and checked the unit and it looks fine. Should I just replace the cluster as it appears that it is just the window part that is faulty. Also appears that this switch is not very common as it has two plugs in it and comes on a base line 2.0d model. Most of the ones I've see are one plug only. Is there anything I should check as BMW quoted ne R2800 for a replacement unit.
I've been able to open all the windows with the key fob however the drivers door window will not go up, only the other three so looks like i'll be taking the door panel off to put the glass back up again. If anyone has a solution it would be appreciated.
Thanks
getty150
Love to see pictures of the master control switch plug in side.
Sent from my TMAF035G using Tapatalk
Ozzycat
Not the best picture but you can see the two plugs. Dealer swopped it out with one off their donor test car and everything worked so looking for a used one at the minute. Seems all my switches gave up at the same time - clock spring, window switch and most probably the wiper stalk as well.
