i can select USB but it doesnt do anything, theres also no power at the USB port, i connecting my phone cable to the usb and it does not charge my phone
@General.Massacre thank you sir for your guidance and help, I finally have bluetooth and usb, after a lot of investigating I found that the problem was the actual USB port, the 5volt pin was slightly corroded, I am truly grateful 🙏 for your help, bless you buddy
thanks @General.Massacre my last 2 niggles is the MIC doesn't seem to work, i did install the MIC it in the dome light and I cannot find the Bluetooth antenna, I checked the panel by the peddles and there's no wiring for the antenna, will have to follow the wiring from the MULF and see where it goes, even though there is no Bluetooth antenna my phone does connect to the car and am able to make and receive calls, i read on one of the forums that the MIC wiring needs to be modified somewhere behind the glove box but i don't even see any wiring for that either
