Retro DJSA
Hi All, Need help to decide if should buy an E46 2003 325i. Seen on YouTube mixed views (haters & lovers). Is this a good/bad car? Is fuel consumption ok? Are parts expensive....Thanks in advance !!!
Thanks so much for your prompt reply. I seen on YouTube as well more people prefer the E46 to E90. Will take into consideration your advice. Much Appreciated...Take Careyou will need find 1 first then check its maintenance History. That will determine if its a Good or bad car to get.
Fuel consumption is dependent on If you going Manual or Auto
Parts are relatively cheap for the E46s. ( Can get expensive if you have allot of preventative maintenance to do on the car you find )
I found the E46 330i to get better fuel consumption than the 325i ( had both )
Averaged around 12l/100km on my 325i and on the 330i, Im currently on 10.8l/100km. Mixed Driving
Overall, im biased to the E46 so im of the opinion its the most affordable "luxury" car currently
thanks soo much for your reply..Noted thanks !!!I have a 2003 325i exclusive, bought it in 2007 with 32,000km on the clock. Car hit 200,000kms last week, standing on 200,600kms now.
All I am spending money on now is general maintenance and the odd old part that is breaking, like a coolant hose here, a vent breather pipe there, leaky radiator...stuff that go with old age.
Services are cheap, and can be done yourself with a few tools. Brakes and that as well, easy enough to do yourself.
Mine has a full decat, 57mm twin freeflow exhaust, and I drive my car hard, being a spietkop you know, I am always chasing suspects. I average 11.7-12.2L/100km and only drive town.
On the highway i get 7.8L/100, but in 2019 went down to ATKV Natalia from Pretoria, used the cruise control on 125km/h most of the time, and did 6.2L/100km.
Look, I've had my baby for 15 years now and love my car, won't get rid of it very soon. Yes, she is not the fastest, yes she is not the newest, but she is mine, and a all rounder, and a BMW.
thanks soo much for your reply..Noted thanks !!!As mentioned above, the answer to whether a 325i is a maintenance headache or not depends ENTIRELY on which specific example you choose to buy.
With the age of these cars, many of them have a huge maintenance backlog that has accumulated and been deferred. But, If you find one that’s had a loving and proactive owner, then it’s very manageable.
You’ll want to research common failure items on the e46 platform such as cooling system, oil leaks and front lower control arm bushes.
A well looked after e46 is a lovely car. I would recommend driving one first to see if the overall driving experience and performance are sufficient for you (only you can decide this).
Fuel consumption is likely to be on the heavier side in town, and pretty good on the highway.
I agree with circa 12L/100km in town, and somewhere in the 7s on the highway.
Good luck.
Good luck.
Yea, agree. Normal issues with these cars, lucky not too expensive to replace if you replace it with proper quality parts: In the past 14 years:As mentioned above, the answer to whether a 325i is a maintenance headache or not depends ENTIRELY on which specific example you choose to buy.
Good luck.
Never owned an E46 so cannot say if it is better or not than the E90, but from an owner of an E90, 330i it is a very under rated car, it has one of the most reliable engines BMW had made, has a good punch to it. Go and test drive one, you will understand.Thanks so much for your prompt reply. I seen on YouTube as well more people prefer the E46 to E90. Will take into consideration your advice. Much Appreciated...Take Care
I would love the N52B30 engine. Its the rest of the E90 I am not a fan offNever owned an E46 so cannot say if it is better or not than the E90, but from an owner of an E90, 330i it is a very under rated car, it has one of the most reliable engines BMW had made, has a good punch to it. Go and test drive one, you will understand.
