check with your local dealer if the black oil special is still valid, it was R4700 for 3 oil services over 24 months. so about R1566 per oil service.Hi Folks ,
scratching my head abit here ,
what should an oil change cost on a f15 X5 3.0D through a workshop ?
Around 1.8k is the normal price at a dealer for 30d'sHi Folks ,
I think you are confusing oil filter and fuel filter.Ideally you should be change your fuel filter with every oil change on a diesel which is part of BMWs process for oil changes. That special at Bmw is well worth it considering their labor, parts and oil used.
Nope. Fuel filter. Every oil change I’ve done thus far at BMW the fuel filter was changedI think you are confusing oil filter and fuel filter.
Oil filter is changed with every oil service.
Fuel filter is changed every second oil service if im correct.
The X3 has been to BMW twice already for oil services and they have never changed the fuel filter (granted I do 10k intervals). I changed the fuel filter myself at 100k, prior to that it was changed under plan at 50k.. Even the quotes from BMW themselves don't include this under the oil service spec, unless you specifically asked for it to be done with your oil service?Nope. Fuel filter. Every oil change I’ve done thus far at BMW the fuel filter was changed
Thanks for the insight into how BMW do your oil service with a fuel filterOkay then. Good luck
