Hi there guys, having a weird issue with my Z4M, just need some advice on next steps
>Process
Opening the car with key fob button works
Inserting key into ignition slot,
Turning to position 1 power picks up
Turning to position 2 (Here is issue) usually the dash lights will pick up immediately, fuel pump will prime, temp gauges go on etc
*Problem is, now this is intermittent, will turn to position 2 and nothing will go on (only airbag light will go on)
*if I wait a bit the car will pick up and everything goes on, or if I turn the key back and forth it will eventually pick up and everything primes/turns on*
>Has anyone else had this on an M car or e46 M3? Potential issues are fuel pump going bad, fuel pump relay, crank position sensor or the DME
Will run codes tomorrow on OBD scanner
Any hints would help,
Clive
>Process
Clive
