zabbo
I bought an e46 M3 with a CSL style carbon fibre bootlid only to discover that water is seeping into the boot area because the bootlid is not sealing properly.
I was advised to just replace the carbon fibre bootlid with an OEM bootlid to address the issue but I like the look of the CSL style bootlid.
My options are:
1. Replace the carbon fibre bootlid with an OEM one, which should sort out my problem. Replacement item is about R3500 for a used one (not sure how much fitting and re-spray would cost).
2. Try and adjust the fitment of the current carbon fibre bootlid and see if it sorts out the problem - not sure if this is possible and if the bootlid will be damaged in making the adjustments. Do they generally fit properly or is fitment always an issue?
Pretty straight forward, so why am I unsure 🤔
Do I swop the CSL style bootlid for an OEM item - are they worth about the same? Or do I keep it as is?
Your valuable input is welcome, especially if you have experience with a similar problem!
My options are:
