Update @ 65,000km:
The car is due for its final free service (5 year/100,000km) next week Saturday (5 June). The plan expires in October.
Today, the driver side door lock switch breaks off and falls into the hole in the panel (picture below).
Admittedly, I do drive over some rough gravel roads and trim items like these may be likely (though not expected) to pop off.
This is the first time something has ever broken off on this car.
I don't know if this is an omen of more unexpected things going wrong (I hope not!).
Anyway, the cost to fix this (which involves stripping the entire door panel and fitting a new replacement switch) is R1,700.
Gladly, since the car is still on Maintenance Plan, this will be covered.
However, it is not smooth sailing yet - the car first needs to be booked in to assess the panel, pictures have to be taken of the fully opened panel and submitted to Volvo SA for authorisation, then the parts will be ordered.
I will take the car in soon for the authorisation check and then hopefully the new switch will be ready in time for the 5 June service.
I am not yet convinced that I need to fork out tens of thousands now for an extended Volvo warranty or maintenance plan, so let's see how things go after the plan expires.
In the meantime, the passenger door switch can be used to lock/open all the doors in the car (when inside) and the car does have auto locking on pull away (the passenger door switch illuminates when all doors lock).
