danieltau
reacted to
Tinuva's post
in the thread
technical
with
Like
With the OEM mounts, when you drive hard lets say on a mountain pass, the gearbox move left and right while in the corner. This means...
Oct 5, 2026
danieltau
reacted to
M3boi's post
in the thread
technical
with
Like
What a fantastically detailed project, thank you for sharing!
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eleven - Engine Timing and Getting Final Items Wrapped Up The plan was to get everything close to lined up and finalise in the...
Oct 5, 2026
danieltau
reacted to
Peter@AEW's post
in the thread
technical
with
Like
Bravo! Big End Bearing clearance is 0,030 to 0,070 typically so you are mid point which is excellent. Looks like a solid build!
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Nine - Measuring Things Main bearings measuring right in between tolerances The big end measured fine as well...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eight -The Cleanup and Cylinder Hone Start cleaning the crankshaft and oil squirters Once the varnish is removed, the crank...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
I ended up doing CAMs too, it's going to need a tune to get the benefits though
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Six - Rings, Bearings, Oil Pump etc. Since the rings were the source of trouble since new, I was determined not to use the OE...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Five - The Head I see some suggestions, so I will get to it, the head was gas-flowed with CAMS, all done by Vanderlinder...
Oct 5, 2026
reacted to
Yash2468's post
in the thread
My G82 M4
with
Love
A little update......not BMW related. Not much happening with the Beast lately—it’s just going along nicely. Life has been so crazy...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Oct 5, 2026
danieltau
reacted to
Peter@AEW's post
in the thread
technical
with
Like
Nice write up. You might wish to reconsider porting the head unless you are changing cams as well as injectors. The heads are typically...
Oct 5, 2026
danieltau
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Oct 5, 2026
