F
replied to the thread
F20 120D M-sport
I think your consumption depends on your daily drive. Say if your trip consists of a small distance that's mainly root to robot then id...
Nov 25, 2025
F
F20 120D Msport
F20 120D M-sport
Also another thing , where do you fill up ? I prefer BP , as far as i know BP and shell has the best quality fuel
Nov 25, 2025
F
F20 120D Msport
F20 120D M-sport
Thanks bud i will buy the diesel injector cleaner and put it in the next tank(half bottle) Where can i do a smoke test?
Nov 25, 2025
F
F20 120D Msport
reacted to
AshG108's post
in the thread
F20 120D M-sport
with
Like
I have not experienced many 20d/30d with injectors issues but nothing wrong with checking it out, especially if it is a second hand car...
Nov 25, 2025
Quintin140
reacted to
Bugger's post
in the thread
🤦‍♂️ So this happened....
with
Like
So an update, if it's worth anything. I have discovered that this car is far closer to an F10 M5 in terms of personality than I thought...
Nov 25, 2025
F
F10 Damper pulley issue
@lo Are yous till happy with the BBR damper? Did you buy an OEM bolt? Did you also replace the belt?
Nov 25, 2025
F
discussion
Vibration damper pulley
Any update on the Bbr damper? Is it a decent alternative to Oem?
Nov 25, 2025
boost3d
PCV bypass
It would help if you told us what model and engine your car has. I did the pcv delete and vacuum side catch can from burger motorsports...
Nov 25, 2025
Jared09
reacted to
Urban963's post
in the thread
Oil in plug well
with
Like
AI Overview The most likely cause of oil in a BMW B52 spark plug hole is a leaking valve cover gasket, specifically the inner gasket...
Nov 25, 2025
F
The interesting video thread
Nov 25, 2025
F
reacted to
Bugger's post
in the thread
with
Like
Nov 25, 2025
boost3d
reacted to
Bugger's post
in the thread
with
Like
Nov 25, 2025
Chinoza
reacted to
Bugger's post
in the thread
with
Like
Nov 25, 2025
