Zack
Hi guys
So last night after taking a drive to a friends house I decided to put the roof down as I usually do when it's a nice cool evening. When I wanted to put it back up it went about a 3'rd of the way and stopped? It had done it before so what I did is just put the ignition off and on again and it worked. This time around every time I do that it moves about 2cm and stops again. After about 5 minutes of struggling I gave up and checked if it will go down. Witch it did??
So now. The first question... Is there a possibility that the button is just faulty or a sensor that is busy going? You can't hear the motor running when you press the button so it can't be that the roof is stuck.
Question no 2... Can I somehow put the roof up manually because Murphy law is that the weather isn't playing along for a guy that's roof can't go up...
Thanx
Z
Thanx
Z
