Contact Moranor from Axis he can help with Meyle HD components. They are actually better than Oem. I also wouldn’t replace 1 arm and would replace both at once :thumbs:
The request for the replacement parts are based on the feedback i received from the wheel alignment results. They could not do alignment for rigth front wheel, and could not set the camber, caste and toe within the specified ranges.
Tie rod end R 255 each
Lower control arm Bush R 510 each
stabiliser bar Bush R 355 each (can only get these in Powerflex if you want Rubber you will have to get from BMW)
stabiliser bar end link R 290 each
Managed to replace all front suspension part accept the lower control arms, and same suspension parts as the E36 model were used accept for the stabiliser links. The wheel vibration similar to an unbalanced weel has been resolved and the alignment has been set.Thank you for the advice and assistance
:rollsmile:
Car simulated wheels balancing problem so I took it to alignment place in Centurion and they could balance the wheels but not setup alignment due to tie rod end bent. I than inspected the front suspension and found the bushes and rubbers were worn and tie rod end was sligtly bent. Checked on the BMW forum and recommended that you replace the tierod ends, lower control arms and bushes after 100000k's
