Yellow warning and limp mode
grim101
E90 320i BMW
120 000km
Car suddenly showed a yellow engine warning light and went into limp mode. I took it to a garage and they sw on the computer its a valvetronic internal fault. What does this mean? Is it bad?
He checked the oil and it was just above min-mark. Said I must top up the oil as this could be giving the error.
Also theres a thump noise on the front suspension when going over bumps or holes.
I got the car yesterday so they must sort out the problem, right?
Ralf*
grim101 said:
E90 320i BMW
120 000km
OH YES, straight back from where it came from, they must fix or re-imburse
grim101
Its in the garage. They gonna look it over and seek out all the problems.
Ratslaaf
Those N46 motors do have VVT issues. Usually it's the VVT motor itself, a VVT fault in the ECU is less common.
grim101
Is it expensive?
Muhammede
That's the Vvt motor (under 2k to replace). The thumping noise is probably control arm Bushes (not expansive)
Sent from my D6503 using Tapatalk
grim101
At the garage. Gonna go see in a hour whats happening. There maybe more niggles they must fix.
grim101
They found a few other problems as well.
Steering rack
Steering ends
Ball joints
Oil cooler leak into radiator
Taking it to abother garage to get fixed tomorrow.
grim101
Car is still at the garage. Hearing tommorow what the status is on the repairs
grim101
Car is back. They said theres nothing wrong with the front suspension. Also there was a new oil cooler on the car and they suspect that the radiator was not flushed properly. They flushed it.
They also replaced a sensor on the airbag resetting the light.
Going to take out a full warranty with IMPACT also. So in future they can just repair the car.
grim101
Vvt servo motor has been replaced. Light is off and car is running nicely. There seems to be another annoying sound...
When the car is pulling and when you take foot of petrol there is a humming noise coming from the back of the car. Sound like a diff?
When the clutch is pressed and the car coasts the sound is gone.
Any advice regarding the diff?? Must the garage fix it?
