johanv said:
I am a current Discovery 1 owner looking for an alternative (pre-owned). Do a lot of touring, towing a 1.5+ ton trailer. Typical Namibia, Botswana, Zambia trips - sand and semi-rugged terrain.
How is the X5's off-road capability?
Is it a good towing vehicle? Sufficient torque low down?
What about the gear box troubles? Is it fairly common? Seems costly to repair.
General maintenance cost? Reliability?
Would the X3 be an option?
I have an E53 (previous shape) X5 and while it makes an awesome on road vehicle, my opinion is that it is not a decent off roader. Yes, it will tackle the occasional dirt road, but that's it. Also the newer ones don't come with a spare, and the runflats are not going to help you when you run into trouble. Avoid the sports suspension, as it's going to be painful if you drive on rough terrain.
As far as towing goes, I usually tow a bike trailer (with a single bike on it) without any hassles. Engine has enough low down torque - no issues with the auto box yet (but I have heard of guys with gearbox issues on the X5). Towed a heavy trailer (about 750KG) as well once, and was fine.
I don't think the X3 will fair any better ... but that's just my opinion. Used X5 is a better buy as it comes with lots more toys.
As far as reliability goes, I've had no issues with mine (touch wood :mmm: ). They share quite a bit of mechanicals and parts with the rest of the range, so it should be reasonable to repair if things go wrong (provided you stay away from the stealerships). As a family vehicle with some off-road capability I don't think there's any better out there. But as a serious off-roader, look elsewhere.
