X5 4.6is
Mastertek
Hi guys I'm new to the forum so just wanted to know if u guys can help me with something. I have a X5 4.6is which recently overheated and ended up having no compression. When the motor was stripped we found all the pistons damaged. So my question is if anyone knows where I can get a sub assembly or if there is a conversion that can be done with the 4.4i block?
Tyx
Wouldn't it be easier to source a 4.4i engine and install it. 4.6i engines are very scarce. I hope mine stays in tact. Taking mine end of month to bmw for service and to check cooling system. had to top up water a few times past few months. hopefully can be sorted under warentee.
what is the difference between 4.4 and 4.6 motors? can 4.4 do duty in x5 4.6is without mods?
Peter@AEW
There is an Engineeering works in Pretoria that will re sleeve the block.
The 4.4 block may be used however you will have a 4.4 displacement.
