Pho3niX90
Hey guys..
So I received my diagnostics cable from the states and my vehicle back from the mach yesterday..
So I thought lets do the diagnostics and check what problems are hiding, hope some one could share some light on them as I have no Idea what this car is telling me..
Also, The Mech replaced the brakpads and the sensors, but the check brake linings still appear, is this normal?? I tried clearing the errors on the diagnostics cable, but it still pops up..
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME* -> 7.522.800 0F xx 2 errors
EGS -> 7.512.653 2B 24 no errors
EWS -> 6.905.667 03 08 no errors
ABS -> 6.761.979 51 03 no errors
LEW -> 6.760.232 04 04 no errors
A/C -> 6.927.898 74 72 1 error
SRS -> 6.912.755 10 32 2 errors / 2 errors
IKE -> 6.914.930 19 15 1 error
LCM -> 6.928.931 04 51 no errors / 3 errors
ZKE -> 6.920.822 21 16 1 error / 1 error
MFL -> 0.000.000 01 10 no data
PDC -> 6.932.985 01 16 4 errors
AIC -> 6.923.954 40 32 no errors
RAD -> 6.922.510 02 81 1 error
SZM -> 8.373.740 00 FD no errors / no errors
VID -> 6.923.268 06 16 no errors / no errors
NAV -> 6.920.182 10 12 no errors / 3 errors
VMGP -> 6.920.182 10 12 no data
RDC -> 6.759.023 02 10 no errors
SES -> 6.915.047 11 06 no errors
EHC -> 1.092.396 00 65 no errors
SMF -> <found> unknown
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME* -> 8C/03 - Activation, map cooling
21/03 - Function, inlet-camshaft control, bank 1
A/C -> 0A/44 - AUC sensor
SRS -> 0C/42 - Passenger's airbag, stage 2, resistance too high
04/42 - Passenger's airbag, stage 1, resistance too high
Shadow-memory:
04/40 - Passenger's airbag, stage 1, resistance too high
0C/40 - Passenger's airbag, stage 2, resistance too high
IKE -> BD/D0 - Electronic braking-force distribution
LCM -> Shadow-memory:
5A/22 - Brake pads
8C/24 - Rear left side light
8D/24 - Rear right side light
ZKE -> 95/21 - Interior security: fuse or cable
Shadow-memory:
63/21 - Power window motor, rear, passenger's side
PDC -> 10/C6 - Converter, rear left
11/C6 - Converter, rear right
12/C6 - Converter, rear centre left
13/C6 - Converter, rear centre right
RAD -> 00/21 - Energy saving mode active
# SCAN END
Any help would be highly appreciated.. Thanks :=):
# ERRORS IN UNITS
Shadow-memory:
5A/22 - Brake pads
Shadow-memory:
# SCAN END
