imp:
Here is a post from my thread about my car, I did it wrong, and it looks like you also made the same mistake as I did...
Wednesday: Started work at 06:00, and as I parked my car in the basement and switch her off, BANG!!! PSSSSTTTTT!!!!!! Radiator preasure tank, or watever it's called, the bottle that holds the water ok... blows up!! Once again calls in favours, Willem AGAIN, for the parts, R650 for the bottle, and R190 for the antifreeze Frikkieh to help me fit the shit, hell, frikkie even volenteered to tow my car from my work to his house, but I called my insurance, and 30 minutes later, free loadbed truck taking me for free to frikkie's house.
Strip out airbox, radiator fan and all pipes, and fit the new bottle and connect the whole system, put in the antifreeze, then, spot one rubber o-ring lying on the floor... strip everything off again, fit o-ring, fit everything else and fill up till level indicator is on correct level, but the car keeps boiling...
Call up Willem, he explains that you need to take out the breather plug, open the bottle and fill it till the water comes out the breather plug hole, then put back the plug, close the bottle, and start her, for 2 minutes, open bottle again and check level, then all will be ok.
