Wheel bearings
Solo Man
Could be tyres. Try another set of wheels first, often the tyres that are making a noise similar to shot bearings.
Nick
Jack the car up so the wheel is free to spin.
Hold the spring with one hand and spin the wheel, if you can feel a vibration through the spring your bearing is toast.
Ralf*
Go for a drive, don't use the brakes to much, so as not to induce brake heat into the hub
once stopped place your hand on each wheel centre cap, the one that is a lot hotter than the other three is your defective bearing
if you do any aggressive braking, then you will not get a good temperature feel, as the temperature build-up from aggressive braking will mask the temperature build-up from a worn wheel bearing
