Wheel bearings
Slamz
when the wheels fall off:roflol::roflol::roflol:
it usually would begin with a soft humming sound which then gets abit louder as you go along... so when you hear your wheels play the tunes... its time to change :tease:
Raybimmer
When you drive and turn left and hear a rumble it will be the right hand bearing under load making a noise .same for other side . Sometimes you can jack car up and hold wheel at 6 and 12 o'clock positions and try movi it around , play in the 3 and 9 o'clock positions is steering rack , tie rod ends etc and play from 6 to 12 positions is wheel bearing . good luck .
SPIDER
Wow thanks buddy.
