what diesel ?
TOOFAST MP
hey guys on friday i traded the e60 in on a x3 2.0d m-sport what type of diesel are these suppost to run on ?
thanks
R
Rolf
If you wanna go pro environment then you need to go for 50ppm
In layman's terms you can regard sulphur in diesel just like lead in petrol, except that lead is added and sulphur is part of the process in crude oil.
So from a performance point of view you can boost a 500ppm running engine a bit more than a 50ppm running engine and the exaust gasses stink a bit more like Sulfid but thats all.
Clownshoe
Sulphur breaks down oil. So sulphur in diesel degrades the effectiveness of your oil over time... your service interval is calculated on 50ppm diesel.
Sulphur is a lubricant and does help with lubrication in items like the fuel pumps and injectors. But there are additives that increase the lubrication of diesel included in the fuel. Modern diesels are designed to run on this fuel and teflon coatings on wear items and such make up for the less lubrication.
If you are worried about lubrication rather use 50ppm and an additive.
TOOFAST MP
:praise::praise::praise::praise:50ppm it is then the longer intervals from the stealership is better cheers :biglol:
herr bmw
on the early navaras,the oil services are every 7500km.
we put in 50ppm and every third to fourth tank 500ppm
