Welcome GasFed m3
BMWFanaticscoza
Administrator
Hi GasFed m3, and welcome to BMWFanatics.co.za :thumbsup:
Tell us a little about yourself and what you drive ;)
To get your hands on some BMWFanatics.co.za stickers like these, Click Here.
GasFed m3
Well I have to say thanks for the warm welcome:wave:
As far as I go I am pretty much a pertolHEAD just like all of you and I drive a mazda 3.0L crd supercab, but when I drive for fun its a custom E36 Turbo M3 which cost me a wife and more money than I dare to mention and that is pretty much that LOL
GasFed m3
Thanks for the kind words guys, I have had the car for about seven years or so, I first had it turbo'd by Sav and then decided to strip it down and rebuild it the way I wanted it, its taken me about three years to get the car to where it is now so its been a labour of love with a bit of hate and a couple of swear-words mixed in.
A basic rundown of the setup.
knife edged and cryo treated crank
arp main and rod bolts and head studs
cryo treated s50b30 block with pyrimid rings that cut into the s50b32 head to seal the combustion chamber, the head was also flowed and received a valve job with oversize stainless exhaust valves.
JE 8.3:1 low compression pistons
Pauter rods
Custom radiator
Custom top mount tubular exhaust mani
Custom intake mani and cooler piping
4inch stainless exhaust with two magnaflow boxes
Precison PT74gts dbb turbo .96 hotside
Tial 60mm wastegate
Nuke performance fuel rail and 76mm PPF dump valve
1 intank plus 2 bosch inline fuel pumps and 1000cc delphi injectors
aqumist HFS-5 direct port water meth with ATL well cell in the boot
Autronic Sm4 ecu plus m&w cdi
That more or less the rundown on the motor side of things, it has a conservative low boost tune for spring pressure which is 15psi on pump fuel without the methanol activating yet and every now and again she breaks traction in third with 275toyo R888's at the back, with that being said this is very much a straight-line wot car and was built for street/highway/strip not gymkana/track ,as they say each to their own:)
zabbo
Looks bloody awesome :dropjaw:
Job well done ... what do the dyno's say about her performance ?
GasFed m3
I actually haven't had the car on the dyno yet, all the tuning was done on the road, after I have done I couple of k's and turn up the boost I will be sure to post up a vid and print-out
Gizmo said:
Nice to see you joined, car looks wikked!!
Thank you and shot for the heads-up
Avi 333 said:
welcome.great car:thumbsup:
