weird chain saw noise coming from motor
frikkieh
In order of the most economical way to fix this:
1.) Check power steering fluid level.
2.) One more vote for a tensioner pulleys - replace all three. While your at it, the belts.
3.) Worse case - alternator - here is a link with video of how that one sounds:
http://www.bmwfanatics.co.za/showthread.php?tid=24257&highlight=vacuum
Although it does not fit the description of what you car sounds like, this one is described as sounding like a vacuum cleaner.
Power steering pump - never replaced mine, that why it sound the way it sounds :rollsmile:
Philip Foglar
Here are the two vids I took before and after replacing the pre-tensioner pulleys.
This was how it sounded when I bought the car and in this clip just before replacement:
[video=youtube]
And now with the two pre-tensioner pulleys on the main belt replaced - need to still replace the pre-tensioner pulley on the AC belt:
[video=youtube]
gizmowp
[video=youtube]
[video=youtube]
Definate same noise, it gets louder when you accelerate as well hey.
how much did it set you back?
Philip Foglar
[video=youtube]
[video=youtube]
Yep, was at its worst in the mornings of course!
Really not that expensive - got the two pre-tensioner pulleys from Masterparts, iirc they were something like R100-R200 each, the third one roughly the same. Can dig up the slips and check. But check realoem as well to see what they look like - Masterparts have their own parts database so often a case of making sure that they are giving you the correct items.
Here are the two that I replaced - the one that attaches to the alternator and then below it. Easy DIY, just a bit fiddly, but no need to cost a fortune! :thumbs:
