Water/Meth injection kit
M5 Ettiene
My X6 M is running a really high ambient temperature, and we cannot find any bigger intercoolers leaving me with no option but to fit a water/meth injection kit.
Any advice?
Twinz
Forum - Support
Is it water temps or oil temps? Please confirm. Rennzport can assist with a simple Meth/water kit which you can easily install or remove...if you in GP then ZL will assist you with our guidance.
I will inquire about the IC from our down under suppliers :thumbs:
M5 Ettiene
It is the air temp - Thanx for the trouble I have arranged for a kit wit Xcede but please let me know about the IC.
Twinz
Forum - Support
Okay...will keep you posted. :thumbs:
Can you post a close up pic of your car? Forgotten how the XM6 looks like...:=):
What intake do you run?
Ps. Not sure what meth kit xede promotes but ask sherwin to look at the new options and designs out there. Look at a Kit that YOU can control, install or uninstall or tweak when you want to...sure the basic setup they can do because some parts of the install will be completely hidden/stealth and permanent (wiring for example)...You dont want to go to your tuner whenever there is an issue with the kit/flow or when you want to fine tune your meth for track days. The "self-learning" controllers that vary spray from 2psi or depending on your special circumstances are very popular now albeit a bit expensive...
Feel free to PM me for advice even if exede does it for you...i have had many "hours" experience with meth now and keen to share insight...!
