zabbo said:
Full set of Eibachs including fitting and alignment is R2800 at Autoquip in Cape Town.
I enquired just last week.
Thanks for the feedback , but im trying not to get aftermarket springs. want original m3 springs .
thnx:thumbsup:
StK said:
Explain tyre wear :thinking: Cause you may need your alignment done and adjust the camber on the wheels :thumb: Unless of course the wear is due to the tyre actually rubbing against the springs in which case spacers may help.When I put on M3 springs I had the tracking done and tyre wear is even across the tyre :thumbsup:
tyre wear was on the inner wall of both back tyres. that was with the aftermarket koenig springs. had the alignment set many times, but it still had the same result. which is why I want to try original m3 springs, hopefully it would wear even.
:thumb:
:thumb:
