Splash
Update on the message below. I replaced the sensor, the car got better but still stalled, then by a mere coincidence I pulled the wire from the turbo pressure sensor and the car suddenly idle 100% correct and revved aswell. Were can I obtain the sensor, Part number 2 247 906.
I had a guy come test my 320d 2005 model and he reckoned the fuel rail pressure sensor is fault. If the car is running or not, the pressure stayed exactly 400 bar. He said if the sensor is at fault, the computer will create a substitute reading to try and get the car started. I now obtained a brand new sensor from Vishal (thanks again mate) and need to know if I need to reset anything prior to replacing the sensor?
