Timing n42 e90
wonderB
Does wrong valve timing on bmw e90 330 result to a No spark situation...someone timed the timing wrongly and now there's no spark but the fuel pulse works fine...i can see fuel sequentially pulsing with injectors pulled out.
zaleonardz
You dont have an N42 in a 330, N42 was the 318 and was replaced with the N46 in the E46 already.
I would suggest you run diagnostics and see what errors you are getting.
It should not result in a no spark though, just no compression.
