Timing chain tensioner
DonovanPorter
As the title says has any one had there tensioner replaced and is there anything to look out for or sounds that would make it obvious for a replacment. I get a rattle from the motor at about 5000rpm and iam thinking it might need replacement.
J
Jandre
My timing chain and tensioner was replaced a few months ago. I had a slight rattle on idle, but as soon as the rpm picks up a little, it was quiet.
Not similar to what you are experiencing though.
plonkster
Had exactly the same symptoms with the Corolla, even though it has a belt. Noisy at idle, goes quiet as the rpms pick up.
DonovanPorter
sounds like a rattle if that helps , i had a similar noise on my sabre and it turned out to be the tensioner , but alot easier to replace than on the BMW
