335is
Interestingly, having just sat through a press conference detailing the many virtues of the 5 Series' new 3.0-liter N55 single-turbo inline six, we were a bit surprised to hear that the 335is harbors a newly developed iteration of the "old" twin-turbo N54. Surprised, yes, but not disheartened, as we'd still happily get out of bed for an N54-powered waterpick.
BMW is positioning the 335is as an appealing option for club racers – presumably those who can't afford an M3 – and for those who normally raid the aftermarket's parts bin. To that end, Bimmer's boffins haven't just fortified the boost and left the rest of the drivetrain package to fend for itself – they've fitted a higher-capacity cooling fan, mounted a supplementary radiator behind the left air intake and bungeed an oil cooler on the right side for good measure. To take advantage of the system's more robust cooling capabilities, a resculpted lower fascia with bigger inlets has also been specified. And although our prototype tester doesn't show it, by the time they reach dealerships, BMW promises that only models with the folding hardtop will receive foglamps – the coupe's will have been purged in favor of larger air openings.
Thanks to those upgrades in cooling and better breathing, BMW has been able to ratchet up the boost to 11.6 psi (up from 8.7 psi in the standard 335i). Thus, as tuned for duty in the 335is, the N54 rustles up 320 horsepower (+20) and 332 pound-feet of torque (+32) riding atop stiffer engine mounts, with the added party trick of an overboost mode that maxes out at 14.5 psi, delivering 370 lb-ft for up to seven seconds.
That bounty is funneled out to the rear wheels through the buyer's choice of a six-speed manual or seven-speed Double Clutch Transmission (DCT), marking the first time that a twin-clutch gearbox has been offered in a non-M 3 Series. The same basic motor also appears in BMW's forthcoming Z4 sDrive35is, albeit conjuring up a sliver more power (335 hp/332 lb-ft.).
How will you spot a 335is on the street? Exterior changes include the updated head- and taillamps and restyled grilles that are shared with the rest of the 2011 3 Series range, but the 335is gets a few malefic telltales in the form of ferric gray 18-inch alloys, gloss black kidney surrounds and mirror caps, black window trim, a handful of special badges and most importantly, a pair of black chrome exhaust tips poking out 'neath a functional rear diffuser. BMW tells us that while the new exhaust system is less restrictive, they admit that by itself, it doesn't really do anything to further enhance the 335is' performance figures. No matter. What those charcoal pipes do accomplish is a heaping helping of aural engagement, sounding significantly huskier than a garden-variety 335i – even at tickover. Hearing the freer-breathing exhausts caroming around Estoril while standing in pit lane was enough to forgive the Portuguese day's unfortunate gray skies and oppressive dampness, and the added audio inside the car was an even more welcome treat.
Being holistic sorts, BMW has also firmed up the springy bits underneath to help deal with the 335i's added aggression. An off-the-rack M-suspension pack drops the ride height by 10 millimeters and stiffer shocks and springs have been substituted, all particularly welcome changes in light of the fact that we had only ever driven on the circuit once before – and that was the previous afternoon. Interestingly, at 13.7-inches up front and 13.2-inches out back, the brakes have been left alone, though we've never had reason to doubt the 335i's binders in the past.
BMW says that the upgraded engine hardware is good for 0-60 in as little as 5.0 seconds for a coupe paired to the DCT gearbox. Row the gears in the fixed-roof variant yourself and you're looking at a 5.1 seconds. The convertible is a tenth of a second slower, regardless of transmission choice. It's important to note that BMW has a history of underreporting engine power figures and being conservative with its performance estimates, and judging by the acceleration we felt under suboptimal traction conditions – and the fact that DCT cars will be equipped with launch control (something with which our prototypes were not yet equipped) – we're guessing that the 335is is actually capable of clipping 60 miles-per-hour about a half-second quicker than BMW is letting on. Regardless of whether you specify a fixed or folding roof, the 335is packs it in at 150 mph.
More important than raw numbers is the way the 335is feels and behaves, and in this regard, we've only whetted our appetites with a limited amount of laps at Estoril with both the DCT and manual (these prototypes were sadly not plated for street use). Even given our limited time and closed course conditions, we can tell you that we like what we see so far. The 3 Series has always had exemplary balance, and the 335is is no exception, only now it has significantly more power to lunge from the apexes. Out on the circuit, the surplus torque offered by the temporary overboost function allows one to gloss over most track virgin mistakes – braking too early (or too late), or taking a bad line through a corner, and even if you get it spot-on, you'll get there that much more rapidly thanks to the extra power. We're pleased to report that the DCT seems particularly well-suited to the 3 Series' character, and it's similarly fine work on the track, being quicker than the (still excellent) tripedalist setup, especially as it allows for both hands on the wheel at all times.
Speaking of the steering wheel, on the 335is, it's an M Sport piece, as is the shift knob and matching sport seats. Other model-specific frosting includes an anthracite headliner, stainless pedal pads and footrest, along with special badging calling out the model name on the dashboard, tachometer and door sills. Like all 335i coupes, this new model comes with a moonroof as standard fit, something sure to please sybarites but potentially aggravate those who don't want the extra weight and higher center-of-gravity on the racetrack. BMW promises us that it's considering making the roof a delete option, but opting out isn't likely to save any money.
