Suspension
deryck1962
Hi guys. Im looking for lowered( dropped suspension) kit for my e34 535. They are the same as the e34 525 and e34 540. Can anyone help. Deryck 0740602361. Tnks
Sent from my K012 using Tapatalk
well cheapest is just springs these are about 3k I can get you H&R or Eibach springs
how new are your shocks?
at a minimum you need fresh dampers with the springs... if you want cheap grab some cheap replacements from a tire shop these wont be great but better than blown shocks
I can offer quality damper replacements from Sachs or Bilstein at a little more than the budget brands
If you want to do it properly you need a set of performance dampers these will greatly improve the ride and handling but the budget will have to be higher
Ralf*
I can organize from an engineering company, and then you decide on the amount you want to drop and they will do the necessary "drop"
Front R525 each
Rear R385 each
need advanced warning (2-3 days manufacture)
fitment
R350 per front side
R300 per rear side
plus alignment
deryck1962
Tnk u. Sounds good. I will come back to u by next week. I was thinking 40mm rear and 60mm front. What u think. Tnks deryck
DieselFan
I think you're going to rub and scrape.
Ralf*
deryck1962 said:
Tnks what would u suggest
My suspension folks say, not more than 40mm, that way you shouldn't have rubbing issues, as well as your shocks can still handle a 40mm drop, anything greater, and your shocks will bottom out and you would ideally need shortened shocks.
generally as soon as the word "shortened shocks" comes into the equation, then the cost radically increases and then the general suggestion seems to be coil0overs
deryck1962
Hi guys, looking for the right side window mechanism complete on an e 34. I was told they all the same. Let me know price, i live in benoni. Tnk
