bac said:
Crash_Nemesis said:
bac said:
i contacted Pieter on the forum, will swing pass friday to see if he can assist me, its def a wiring or vacuum issue on mine
Again... what kit are you running, what size pulley wheel do you have?
its a old 99/01 year RGM kit based off there vortech V1 race charger. Not to sure on the pulley size, i just removed it out from a RGM car, transplanted with the motor/charger/ecu.Upon installation could of missed or incorrectly fitted a wire or vacuum line.
Thanks for the reply. I think what I am about to type below might be your problem.
What car did you take the charger off? What crank pulley size does that car have? Is it bigger or smaller than your cars crank pulley?
The reason I ask is that the crank pulley size also determines the impeller speed of the supercharger. If your engine's crank pulley is smaller than the car the supercharger came from, you will be running less boost.
To increase boost you can either have a larger crank pulley or a smaller supercharger pulley. If that supercharger came off an e46 330i for instance, the crank pulley on the 330i is larger than the pulley on an e46 M3 for example. So, lets say the 330i was boosting 4 psi, that very same supercharger setup will run 1psi or less on an M3 engine if using the same pulley on the charger. So unless you change the supercharger pulley to a smaller pulley or change the M3 crank pulley to a larger pulley, the car will make less boost. Also, volumetric efficiency comes into play. An M3 engine is more efficient than a 330i engine. You'll make less boost there too. In other words, you need to spin the impeller faster on an M3 engine to make more boost.
I hope this is making sense.
Let me know what car the supercharger came off from. THen we can start calculating what size pulley wheel you need. Also, find out what PSI that car was running. This will help too.
