Stock just in - Crazydetailer
Pravin@crazydetailer
Daytona - Speed Master PRO Wheel Brush
The Speed Master PRO Wheel Brush makes extreme wheel cleaning easy, day-after-day, year-after-year. This industrial-quality wheel brush is designed to exceed the requirements of heavy-duty wheel cleaning in a professional environment, making it perfect for professional detailers and enthusiasts alike. Because the Speed Master PRO Wheel Brush proudly wears the Speed Master name, it features soft, non-scratching bristles that are safe for delicate wheel finishes while providing the cleaning power to handle stubborn brake dust deposits. Clean your wheels like a pro with Speed Master PRO Wheel Brush!
LakeCountry Mfg pads are back. We have the 6" CCS and the 6.5" flat pads. These have always been a firm favourite amongst detailers and enthusiasts from around the world. Note, that the flat pads are not the same as the hydro tech pads.
Lake Country’s CCS Dual Action 6 inch Smart Pads™ Foam Pads are flat full contact buffing pads that work with your dual action orbital polisher to correct automotive paint more easily than ever before. The CCS Smart Pads™’ user-friendly features provide better control, less product waste, and a more successful detail.
If you’re a fan of the original Lake Country Flat 6.5 inch Pads, take advantage of this limited opportunity to stock up.
The Lake Country Mfg design team came up with a way of improving upon the 6.5” foam pad – add more Velcro® brand fasteners! The material goes almost the way to the edges of the pad to ensure the most contact between the backing plate and the pad. This gives you the best hold on the pad as you polish. Plus, the increased Velcro® brand hook & loop material means you can use the 6.5” pads with 150mm backing plate. You can even use these pads on your rotary polisher because they accommodate a 150MM rotary plate. Flat pads are now suitable for both rotary and dual action buffers!
Warm up this winter with the warmth of Carnuaba.
Those who have bought the Blackfire Wet Diamond All Finish Paint Protection will know the depth and gloss that just the sealant creates. The Midnight Sun Ivory Carnuaba is the perfect partner to the wet diamond sealant. Add the warmth of Carnuaba to your already glass like shine. Dubbed Fire over Ice in the international detailing scene, this is certainly something you need in your detailing (top) shelf.
Thank you for you continued support! Like us on
sash
Eish..., fathers day is coming..., must add my wifes email to the CD subscription list.
:rollsmile::rollsmile:
Kyle said:
Any chance of a wider range of CG products?
We working on it Kyle. We haven't ordered in a looong time. The only stock we regularly get is MaxiSuds.
We in negotiations ... Anything in particular you looking for? We will be bringing stock in but it will be higher volume but reduced range.
Kyle
Diablo wheel gel for one...
Kish2604
Administrator
will be at the shop the long weekend in june... like a kid in a candy store!:roflol:
Prev
Administrator
I need a Daytona speed master brush and a cutting pad....was at the shop 2 weeks ago and didn't have stock.....please PM prices
