Skimming of a Flywheel
V'NOLAN
Hi Guys
Whats your thoughts on skimming a dual mass flywheel?
Ive managed to buy a clutch and can't find a new flywheel. So i have to go with a 2nd hand one. Should i skim it before using?
Regards
V'Nolan
Nikhil
have a look on turner motorsports site might aswell import a jb racing flywheel. :thumbs:
ClassicB
I have heard that it is possible but not recommended, but rather contact these guys to give you advice:
Astro Brake & Clutch
Tel : (011) 826-7000 / 826-2993
I know they do skimming, etc
B16A4
i cant believe you havent found this part. from my knowledge the 3.0 shouldnt be using a dual mass flywheel unless im wrong. try this guy, Quinton: 0762521554. he has a lot of 3.0 spares
V'NOLAN
Called Astro, You can't skim a dual mass flywheel
Gizmo has a second hand one, going to see it this weekend. Spoke to quinton, he has flywheels but not sure if its for an M car.
Anyone used this guy? he can make a flywheel for 6k
Sankekur
A dual mass flywheel can be skimmed if the spring tension is still in spec...you just need to find a place that will do it for you.
If you convert to single mass you will need to find a sprung hub clutch disc that will fit on your gearbox input shaft (even more so seeing as you are worried how the car will be in traffic)
And 6k to me feel on the expensive side for a flywheel.
You will also get a lot more gearbox chatter with a single mass, which is something else to consider if you will be driving in traffic.
K33G4N
Try a 328i flywheel
http://www.precisionrace.co.za/
328i uses same flywheel.
Converting to single mass flywheel will result in more noise from gearbox but flywheel will be stronger.
Their details:
7 Western Service Rd
Wendywood
Sandton
0746673415 - Clenton Pillay
0827796158 - Jerry Sonny
0836519119 - Jose Carvalho
Fax: 086 619 2767
Email: [email protected]
V'NOLAN
After a visit to Gizmo, seems like the 3.0lt is not a dual mass fly. Maybe only certain models came with dual mass
My mac is only available end of next month so I have dibs on Stig4T flywheel else i will go the precision racing route
