Well the small nob on the right(not the left reset nob) on your speedo cluster should set your time on your cluster, turn right or left and set the time, also you can set it to 24H or AM/PM
@ 001asp: no such luck! neither the left or right hand knob can twist and when you hold down the reset button and then press the right hand one the computer display says: test 1
